Saltar al contenido principal
Device and repair information for the 60" LED HD TV by Samsung released in 2013, model number UN60FH6003FXZA.
Preguntas 203 Ver todo
TV hisses, pops, and went out for good
Earlier in August, my grandma's TV turned off during a storm. She tried her first few fixes, she turned off the cable box, unplugged the TV, and plugged it back in. According to her a low hiss was audible, then a loud pop. And it was completely silent from then on, it won't turn on regardless of where she plugs it in, I took pics of both boards, green is the connections and orange is the power board.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Hissing and popping generally would point to a PSU problem, specifically:
a capacitor
1 or more diodes
a device on a heat sink
In that order.
I don't see anything to indicate a bad cap. I can't see the devices on the heat sinks, so one of them might contain some charcoal.
Start with checking the fuse.
Then eyeball and smell the board.
Then test the diodes with the diode function on a DVM.
Replace parts as necessary.
I'm betting the fuse and a diode or two.
Fue útil esta respuesta?
Puntuación 0
@blueicefrostyy looks like your power board got hot (very hot) check the area of the red markings. The IC's thermal paste does not seem to healthy either. I would consider that the sizzling culprit. Removing the board and checking it from the bottom side may also shed more light onto this. The very first checks would have been to see if your POwer LED comes on, if you have power on the board at the fuse and if you have the standby voltage as shown on the board to be at 13VDC. Use a multimeter on DC settings and place red probe on the pin as pointed to on the board and black probe on ground. Since this is going to a kive test (plugged in and turned on) there will be power on the board. Do not touch anything with your bare hands. Could be a shocking experience. If you do not have that, you could try and find a schematic for the board or replacing the board.
Puntuación 0
Añadir tu respuesta
Drew Oliver estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 41
