Saltar al contenido principal
iPhone de cuarta generación. La reparación es sencilla, pero el cristal frontal y la pantalla LCD deben ser reemplazados como una unidad. GSM / 8, 16, o 32 GB de capacidad / Modelo A1332 / Blanco y Negro.
Preguntas 2375 Ver todo
Pregunta Cerrada
Completly dead iPhone 4
Hi i have an iphone 4 which is completly dead. I have tried the logic board in a different body and still the same. So in other word the logic board wont boot up. Does anyone know if this could be resolved by changing the powermanagement ic ?. Hope to hear from you. Thanks again.
Es esta una buena pregunta?
Puntuación 0
2 comentarios
of course you did use a different battery when you switched it over?
- de
Not recognised by iTunes dead or no lights/chimes dead. Maybe it's in dfu mode which gives black screen/dead appearance
- de
Agregar un comentario
1 Respuesta
Solución Elegida
The only way to say if changing the power management IC will work is if you can tell us for sure that this is the part that failed. There are many ICs on the logic board as well as many small and rather sensitive paths; this leaves the odds of there being damage else where very high.
In addition, replacing ICs is no small task and will require something a little more refined than a soldering iron.
So if you know for sure that "power management" IC is your culprit, you know that there is no damage any where else, and you have the correct tooling, rock on! Otherwise my bet would be that replacing this one IC would not work.
Fue útil esta respuesta?
Puntuación 0
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 855
