it dosen't turn on after it fell in a swimming pool
my jbl flip5 fell in swimming pool and dosen't turn on
Es esta una buena pregunta?
Hi
Unfortunately this one sounds like water damage;-{
The best thing you can do here is act fast!
Here’s some steps
1)if possible turn off and disassemble the device by following this video
https://m.youtube.com/watch?v=uPFoKEKoT_...
2)look for any corrosion or blown components (corrosion usually looks like white blue or green stuff)
3)if any corrosion is found clean it away with isopropyl alcohol and some qtips/cotton buds
I would also pay close attention to the aux and charging ports and make sure they are clean
If this isn’t something you want to do or it doesn’t work I recommend taking it to a repair shop
Hopefully this helps
Any questions please ask
Fue útil esta respuesta?
The flip 5 is ipx 7 up to one meter. If it was a quick dip it usually should be fine. The port covers can’t of been closed properly. As before it’ll need stripped, dried out and cleaned. Trying to turn it on after going for a dip might of shorted out some components on the board too.
Ultimas 24 horas: 5
Ultimos 7 días: 39
Ultimos 30 días: 115
Todo El Tiempo: 1,120
