Saltar al contenido principal
{A1706 / EMC 3071}: lanzado en junio de 2017, este Macbook Pro de 13 "presenta procesadores Kaby Lake de hasta 3.5 GHz Core i7 con Turbo Boost de hasta 4.0 GHz.
Preguntas 268 Ver todo
Problems with new battery not charging
I have a Macbook Pro 13 2017 A1706 EMC 3163
The original battery was only lasting about an hour so ordered a new battery.
I followed the iFixit guide to installing a new battery.
Initially it was working fine and was showing as good health in Cocnut battery.
It got to about 20 % charge.
I decided to remove the battery as I had not glued it into place as yet.
I was about to glude it into place but tried to re-connect and turn it on.
Now it is saying Battery is not charging and how can it change from 20% to 0% and now it is saying battery health is poor?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
[image|2717884][image|2717883][image|2717885]
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi Paul,
Have you calibrated the battery? The software learns and keeps track of the battery's charge to take what is essentially its best guess at how much charge it has left. When you change out the battery, it's then working off of old data that's wrong for the new battery.
The calibration procedure allows the computer to learn the charge curve of the new battery to correctly report the amount of charge it has. So don't pay any attention to the reported battery percentage until you've run a full calibration, as it will almost certainly be wrong. Here's a guide to the procedure.
Battery Calibration - iFixit Support
Closeup of the battery connector.
Fue útil esta respuesta?
Puntuación 1
3 comentarios:
Hi Jerry, thnaks for your reply. No I haven't but the problem is with the new battery it stays on 1% and won't move. It says battery is not charging. I left the laptop plugged on today for well over 7 hours and nothing has changed.
I have to admit I find the battery connector on this model very poor and very difficult to attch. I am worried that the connector on the motherboard mabe damaged. I now have 2 new batteries and one old one none of them seem to charge any more....What can I do?
- de
The ZIF connectors used are pretty reliable, so it's not all that likely that it's damaged from normal use. At this point I'd suggest opening the case back up and reseating the connector. I added a closeup of the connector with the cable fully engaged; make sure yours looks like that before you snap down the locking tab. While you have it out, it wouldn't hurt to clean the contacts on the cable with isopropyl alcohol; you should preferably use some with a high alcohol percentage; the 70% stuff we normally have around the house isn't ideal, as it frequently has additives.
If you want to take a couple of pictures before you button it up, that might help us diagnose if there's a visible problem or not. A picture of the flex cable by itself and a photo once it's been locked down would be good.
- de
I have tried to reseat the connector and I have attached some photos. I have ordered some of the isopropyl alcohol off Ebay and waiting for that to get delivered.
- de
Añadir tu respuesta
Paul Sheraton estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 274
