Saltar al contenido principal
Un simple secador de pelo diseñado para secar el cabello. La reparación de este aparato es sencilla.
Preguntas 26 Ver todo
Why the air from my hairdryer is smelling very bad
The air is smelling very bad
Es esta una buena pregunta?
Puntuación 0
5 comentarios
Hi,
What is the make and model number of the hair dryer?
Does it have a "burning" smell?
- de
Check the back of the hairdryer. Sometimes there’s like a mesh that gets clogged up restricting the flow of air through it, if it doesn’t get enough air flow it will start to overheat.
- de
Does you hairdryer have a screen for filtering out debris going into the unit? Did you check for hair getting past it, entering the heating element and cooking hair? Cooked/burned hair usually results from the unit ingesting hair and creating the terrible smell.
- de
@notbroken you’ve just wrote what I said 😂
- de
@strongbow, blocking or restricting airflow tends to allow the heating element to create hotter air temps without burning but any debris like hair getting into a hair drier will burn and melt creating the bad odors.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Try cleaning the filter maybe?
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Rukhsana Begum estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 21
Todo El Tiempo: 254
