Will Battery Disconnection Cause Ipad to Erase?
If my battery is disconnected will it erase or reset the iPad? Do I need to perform a back up before I disconnect the battery?
Es esta una buena pregunta?
Hi Bella,
No, disconnecting the battery won't wipe your iPad. The "disk" storage is held in non-volatile memory, meaning it isn't lost when the power is removed. Just be sure to shut it down first; press and hold the power button and the volume up button on the side of the iPad. Drag the on/off symbol to the right.
That being said, it's always a good idea to back up your device before working on it just to be safe.
Out of curiosity, why are you contemplating disconnecting the battery?
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 42
