Saltar al contenido principal
La Razer Blade RZ09-0102 es un portátil para juegos de 14 pulgadas que fue fabricado por Razer en 2013. También se conoce como la Razer Blade 2013.
Preguntas 5 Ver todo
Why laptop is not turning on?
I have razer motherboard rz09-0327. I have checked the voltage lines, every voltage rail is present, when I press the button on the mother board fans spins, gpu and cpu get warm and everything shuts after approximately 5 seconds, but there is nothing on the diplay. And battery getting charged as well, I tested the voltage. There are no shorts that I could find. What might be the problem? Or where else I have to look?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi @dmakhmammadov
Try a power refresh and check if that resolves the problem, in case it is a corrupted BIOS that is the cause of the problem.
  • Disconnect the charger if connected.
  • Open the laptop and disconnect the battery from the motherboard. (you don't have to remove the battery, just disconnect it). Here's a video that may help. Not your exact model but hopefully it is close enough to help.
  • Press and hold the laptop's Power On button for a full 30 seconds and then release it. This should reset the BIOS back to its factory default settings.
  • Reconnect the battery and reassemble the laptop.
  • Connect the charger and try turning it on.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Diyorbek Makhammadov estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 39
Todo El Tiempo: 197
