Saltar al contenido principal
Lanzado en julio de 2018, el MacBook Pro de 15", modelo A1990, presenta una pantalla de retroiluminación LED de 15.4 pulgadas con tecnología True Tone, TouchID y hasta 6 procesadores Core i9.
Preguntas 173 Ver todo
Can I swap the top case assembly (keyboard, battery) from other mac?
I have a replacement top case containing keyboard, battery, speakers, trackpad, touch bar, is it possible to do a swap on a 2018 macbook pro 15 inch with T2 security chip? I will move the screen, motherboard and touch id together.
I am scared the T2 will lock the machine.
Any ideas? thanks
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
So in truth you are swapping just the uppercase which has the keyboard and battery. If that's the case installing your logic board and Power button (TouchID) and the display will work as long as the two systems are in the same series. In your case both need to be 2018 15" MacBook Pro's, either MacBookPro15,1 or MacBookPro15,3. To double check I would plug-in the systems S/N's here: EveryMac - Lookup
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
alex n estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 86
