display quit, and replacement doesn't work either
My display started getting a green cast, then died within a day. I sent off for a replacement, and once I got it installed, I found that it still didn't work. I'm able to hook up an external display and it shows that the computer is working just fine. Should I assume the replacement display is bad? I am reluctant to ask my wife to let me take apart her old MacBook Pro to try hooking up a different display
It's a mid 2012 unibody
Es esta una buena pregunta?
3 comentarios
Hi
Are there any burn marks or corrosion on the screen connector?
- de HelloMacOS
No burn marks, but there could be corrosion. What's the best way to clean it?
- de bob
The repair I did before the display went bad was to replace the MagSafe input. It worked fine for a few months before the display problem arose, but of course the repair involved unplugging the display cable.
I don't recall any difficulty with installing the cable, but could have done something inadvertently. I assume all the other components you mention are part of the logic board? I that my next project?
- de bob
