What size screwdriver is needed I've tried a t2 which is too big
Can anyone tell me what size screwdriver I need to fix my versa 2 I've been told a t2 which I've tried it's too big x
Es esta una buena pregunta?
Hi
If a T2 is too big try a T1 they are quite similar but a T1 is smaller
Also if it has a pin in the middle it is a security torx and you will need a specific security torx to take it out
Hopefully this helps
Fue útil esta respuesta?
Thank you so much x it actually turned out to be a t2 it's just the quality of the driver I'd borrowed wasn't the best so as advised tried t1 and that did fit then snapped so bought new torx set and t2 fit straight away. Thank you for responding.
@Emma Rowell
Your most welcome:-)
If you need any more help just ask:-)
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 156
