Saltar al contenido principal
El Logitech VX Nano es un mouse láser inalámbrico diseñado para computadoras portátiles. El mouse incluye un receptor USB que puede almacenarse dentro del mouse o insertarse en el puerto USB de una computadora o portátil.
Mouse won't power on
My Logitech VX Nano Wireless Mouse won't power on. I replaced the batteries. And no, the receiver is not in the storage slot. It is not a connection issue; it was working fine, then stopped. Thought it was the batteries, but new ones did not cure the problem. I can't find any troubleshooting for this problem.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
3 comentarios
can u take a pic of the board plz
- de
Hi @kamsh
Had you tried with another computer?
Is the usb receiver detected on the computer? you can check on device manager.
when you pull out the new battery and insert again, do you see any LED light showing up on top of the mouse?
- de
I have the exact same problem. The USB receiver is detected but none of the LED lights are lighting up when batteries are inserted.
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
if its not getting any power light then its a power issue.
did anything happen suddenly before the old batteries die? any possible liquid damage?
might sound silly and i HATE to ask but are the batteries in the right polarity?
and youve obviously tried confirmed fresh batteries?
are they rechargeables ?
have you checked to make sure the contacts are extended enough for the negative to make a solid contact with the batteries?
any corrosion?
if youve checked all that you may need to open the mouse up and take some voltage readings and make sure the board is getting power. if it is then you have a bigger issue and will need further trouble shooting.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
When you insert the nano receiver in is't slot next to battery compartment, the receiver push a button inside the mouse to disconnect power to conserve battery. This function is in replace of a power switch that not available in VX Nano.
- de
The push button inside the mouse need to be cleaned or replaced.
- de
Añadir tu respuesta
kamshopping estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 509
