Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
El primer modelo de iPhone, modelo A1203 con 4, 8 o 16 GB de capacidad y una parte posterior de aluminio. La reparación requiere una cantidad significativa de destreza, y puede requerir un poco de soldadura.
Preguntas 294 Ver todo
battery will not charge after water damage
So my iPhone 2g got rained on a week ago and it powered back on after i immersed it in rice but not too long afterwards the WiFi went off and turned grey in the settings, and so did the network. The phone lights up when connected to the computer or charger but it is stuck in low battery charging mood and wouldn't even charge or boot. I have taken the phone apart and i noticed that the battery is a little too soft for my liking. My question is how do i know if the battery is damaged? when i press the battery it feels like it melted. Is the battery rock hard when it is not damaged? Also how do i fix the issue of the WiFi and network signal not working. Any help will be greatly appreciated.
Thank you
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Comentarios:
rice theory is a myth all you can do is immediately remove battery remove mother board and clean the board with isophrophyl alcohol best you can and hope for best
- de
or if all is working it is still advisable to clean board with alcohol since I have seen water damaged devices work a whole day and the next day they are dead this is what a repair shop would do as a first step or they should anyways the alcohol not only cleans any sulfur and oxidized surfaces but also evaporates quickly
- de
and ya a new battery goes without saying you will deff need to replace it..
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
It's highly recommended to replace the battery after a water damage. Batteries don't really like being short circuited, it could be dangerous to continue using it. And it's cheap.
If you mean iPhone 1G (the one with aluminum back), you should get a battery like this one : [producto vinculado inexistente o deshabilitado: IF105-017-1]
If you mean iPhone 3G (actually the 2nd generation), you should get this battery : iPhone 3G Battery
Imagen de iPhone 3G Battery
Producto
iPhone 3G Battery
$14.99
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
josh estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,455
