Saltar al contenido principal
Información y guías de reparación del iPhone 8 que salió a la venta el 22 de septiembre de 2017. Modelo: A1863, A1905
Preguntas 873 Ver todo
Doesn’t charge if bracket is installed
So I’ve replaced the battery and it’s charging only if the bracket that covers battery, display and home button cable is removed.
If I install that bracket back it’s not charging at all.
It also showed strange behaviour when it would charge with bracket, but when not all screws are in place (doesn’t happen in all cases).
What can be a reason here?
Can I use my phone without that bracket at all?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Check that you are using the correct screws, a longer screw can cause a short and damage to underlying circuit boards I assume you've looked carefully for visible shorts or misrouted cables? I'll get back after I've researhed a bit.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
I know I've seen a video with this problem but I can t find it now!
- de
Hi
This behaviour is really strange and I never really seen before
You can use the phone without the brackets but it isn’t recommended as if the device is dropped it can unplug and prevent the device from working properly
I would try cleaning the connectors on the device and the parts with isopropyl alcohol to see if it’s caused by dirt being in the way of making a proper contact
Hopefully this helps, if it doesn’t give me a shout
Puntuación 1
Añadir tu respuesta
Yolqin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 47
