Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Lanzado el 21 de julio de 2011. Procesador Core i5 o Core i7. Rayo. Esta unidad también se utiliza para ejecutar la configuración de Mac mini Server.
Preguntas 212 Ver todo
Broken ir connector(?), possibly to run without?
Hi,
I have successfully managed to detach the what i think is the ir connector from the logicboard. And therefore I can not connect the wire with 5pins onto the logicboard.
Can anyone please confirm that the cable is intended for the InfraRed function on the Mac mini server 2011?
And please say that I can use my mac mini server without that cable!? Or must I send it to service?
Thanks in advance!
Fredrik
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Comentarios:
It is hard to give you an answer without pictures of what is broke off and where it is located on the board. You have the ability to trace where the wires that connected to the header lead. If you are not sure what they go to, we can't be either.
- de
Agregar un comentario
Essential Electronics Toolkit
Pequeño juego de herramientas. Grandes posibilidades.
Shop Toolkits
Essential
Electronics
Toolkit
Shop Toolkits
1 Respuesta
Solución Elegida
If you can do without sleep and some other functions - they are, I believe, included on that sensor.
Remember to return and mark accepted the answer that best solves your problem.
Fue útil esta respuesta?
Puntuación 2
Comentarios:
Was wondering if anyone had pin assignment info for the IR header, and sensor info. Thanks in advance!
- de
Añadir tu respuesta
Fredriknoren estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 1,386
