My Nintendo switch pro controller won't charge or Turn on
After leaving my Pro Controller charging for more than an Hour it will not turn on or charge. Holding down the Sync button also does not work
Es esta una buena pregunta?
Needs a new battery it seems like. Very easy to replace, all you need is a pretty tiny Phillips head screwdriver. Screw off the screws on the bottom of the black grips, then those 4 screws on the inside. You should be able to pop the backplate off and have access to the battery.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 207
