How to fix the Airflow of this machine
I'm planning to Reapply the thermal paste
And am willing to cut holes in the bottom case
And glue on some mesh,
And I have no optical drive.
Update 5/15/2022:
Es esta una buena pregunta?
If you take the optical drive out you need to block the slot! As you don't want air or dirt to enter though it. I would frankly leave the optical drive in place unless you replaced it with the special drive carrier to mount a second drive.
Airflow is rocket science! Have you ever looked at how car makers use smoke to see how the air flows over the car within a wind tunnel or see the super computer modeling they do?
If you start altering the air flows you are more likely make more of a mess if you don't do the needed modeling first! At least use a FLIR camera to see what the system is doing. When I visited Apple many, many years ago they showed us how they view systems using a clear case and a FLIR camera setup, it was a large machine. Today you can get a FLIR adapter for your iPhone!
But without a clear cover you only see the heat of the surface not what is inside and if you don't have a cover in place you lose the airflows within the system. If you are quick you could pop it off and take a picture without the cover but it doesn't take long for the heat to dissipate. You still need to know what you are seeing and depending on what you are running some chips maybe running hotter or not hot at all!
Bottomline I don't recommend altering the case or the internals as you could make things worse! Just look at SpaceX as they develop the Starship look at all of the versions of rockets they have made as they fine-tune the rockets airflows! Even they have a hard time with much simpler surface dynamics than what you have internally in your MacBook Pro.
OK, My system is running hot what should I do?
To start with Apple gives us a lot of thermal sensors to see what's happening you only need a good tool to access them and present the data in a useful and readable form. I've used a few different tools and I've not seen any better than this one TG Pro Matt keeps it updated and if anything is found to be a problem fixes it quickly. Many of the other makers just don't fix their problems or added support for the newest system as fast as Matt has.
The next step is Keep your system CLEAN! most systems I have seen are loaded with dust and debris! Keeping the fan blades and its cowling as well as the heat sink fin area dirt free is very important! TG Pro will help you see when it's time, and when you need a bit more air flows you have a heavy process running push the fans a bit harder.
Even still, cleaning and replacing the thermal paste (TIM) is also important about every four or so years for most systems. But, its important you don't over do it! Again I've seen systems messed up by glopping the paste! Even Apple goes to far.
Make sure you use just enough to cover the black silicon chip no more!
That leaves the last element of the movement of heat the heatsink its self! I've encountered quite a few bad heatsinks. look for pinholes in the tube area often I see white particles around a hole and/or staining of the logic board right under the hole were the coolant has leaked out.
Just as a primer give this a read Thernal Analysis of the Necessity of a CPU Heat Sink Fan As you can see theres a lot of math involved!
Fue útil esta respuesta?
@danj - Do you recommend the arctic MX-4 thermal paste?
@beanman56 - To be honest most paste's are about the same in effectiveness. I'm sure someone will disagree with that ;-}
Think of it this way... if I hit the barn door is that enough or do I need to hit the wood knot in one of the door panels. Sometimes we go to far! As the differences are not as great as people think.
The question should be how thin will the paste squeeze down to when the heatsink is torqued down! Some paste is very grainy others are very thin. The thinner the better! The distance between the chip and the heatsink needs to be as little as possible. The paste's role is to fill the micro pores of the two surfaces. If both surfaces where polished to a mirror finish and perfectly flat you wouldn't need any TIM!
As I expressed in my answer many people over do the paste. Only the active chip surface needs the TIM and the amount needed is shockingly little!
@danj - Once again thanks
@danj - SO i got done...
And the keyboard is not working right,
I linked a photo,
The F1, 2, 3, 4, 5, 6, etc key work though,
Any ideas?
If "I got it done" means opened and reassembled recheck the keyboard connection and make sure you didn't. accidentally damage anything.
What do you mean by "fix"?
To fix something, it needs to be broken first.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 188
1 comentario
Take a picture of the keyboard ribbon cable end and its socket as that is the focus if your keyboard is only working partly. Review Step11 from this guide Remplazo de la Placa Lógica del MacBook Pro Unibody Mediados de 2012 de 13"
- de Dan
