Volume goes up randomly.
How do I fix Pioneer SX7 receiver volume randomly gets very loud.
Es esta una buena pregunta?
Ken Perrin make sure that you do not have the volume preset. Check to see if the preset step indicator lights up as your volume increases. Of course, you could also try and set the volume to a level that is not overly loud and see if that changes your receivers behaviour. If you are using a remote control, turn the unit around (or cover it to rule out stray IR interference) and see if that changes it. After that, you are going to have to take a look at the inside and see if there are any (and there are multiple) components that looks like it may have failed. is missing, charred, etc. Of course you can always use the SM to check things out. Pioneer SX7 SM. as always, you come across things that look odd etc. post some good pictures of it and post those with your QUESTION. That way we can see what you see and hopefully help you further.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 30
