Saltar al contenido principal
Released in 2017 the ASUS ROG Strix GL503VD is a high performance gaming laptop.
Preguntas 12 Ver todo
Where do I get CPU replacement fan?
Hello,
I have an Asus ROG GL503GE laptop. Recently the CPU side fan has been making scary grinding noise. I have searched almost everywhere to get a replacement fan, I contacted Asus customer care. None could help me, even the customer care representative said the model was very old and they had no replacement fan :(
I badly need to get this fan fixed. Any idea which types of fan will it support? The CPU fan's part number was: FCN DFS2013121A0T, rated at 12V 1A.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi @stackneverflow
If you want just the fan then search online for DFS2013121A0T to get results for suppliers that suit you best.
If you want the complete thermal module then try this one.
According to this supplier there are two thermal modules available.
The first is Asus part #13NR0080AP0101 and it seems to be unavailable, or at least I can't find one.
The second, linked above is for a GL503GE-1B (Asus part #13NR0082AP0301).
I don't know what the difference is but you may be able to check by comparing yours to the image in the link.
You could try searching for the Asus part numbers to see if you can find other suppliers as I didn't look too hard. ;-)
Update (05/05/2022)
@stackneverflow
Try gently peeling off the label from the centre of the fan and see if you can see a bearing. There may or may not be a cap over it I don't know
If you can see it apply 1-2 drops only of light machine oil (sewing machine oil perhaps) to the bearing and see if this stops the noise.
Do not apply more than this as you don't want it running everywhere.
Replace the label in position when finished
Here's a video that may help as it shows how to access the fans once you have removed the cover etc. The fan label can be seen at 13 seconds into the video when the fans have been turned over.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Thank you for taking the time to look up. Unfortunately, I couldn't buy from any of the sources above (shipping cost is showing 200$+). I just need to replace the fan, but they are selling the whole heatsink
- de
Añadir tu respuesta
Anwarul Bashir Shuaib estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 325
