Why wont my phone recives any signal?
After a hard fall my iphone on sparadicly recives any sort of signal, 3g or network. What would be the most likly cause of this?
Es esta una buena pregunta?
Two main reasons this has happened
- Loost antenna connection due to impact force
- Damaged logic board
If the antenna has become loose, all you will need to do is remove the back cover and re-seat. If the logic board has been damaged then you will need to take your phone to apple and request for a replacement.
Fue útil esta respuesta?
usually a loose antenna
you can change your sim card and try it .if that your cellphone doesnt work ,maybe it was broken.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 779
2 comentarios
Seeber, can you tell us which iPhone you have?
- de Phillip Takahashi
i have the iPhone 4 first gen.
- de seeber
