But heater is not working
Warm light turning on. But heater is not working
Es esta una buena pregunta?
***MOHAMMED THAJUDDEEN we would need to know what make and model your popcorn maker is or at least see more of it. Since the warming light turns on it stands to reason your unit gets power. In that case I would suggest you use an Ohmmeter and measure the resistance on your heating coil to see if it has continuity or if it has failed. You also want to check for power as well as check out the thermostat etc. We really would need to know the make and model or at least see more of the unit/wiring etc. to be more specific. Agregar imágenes a una pregunta existente
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 49
MOHAMMED THAJUDDEEN do you have a make and model for this popcorn maker? If not post some good pictures of it with your your QUESTION. Agregar imágenes a una pregunta existente
- de oldturkey03
