Saltar al contenido principal
Lanzada en noviembre de 2020, la MacBook Pro de 13" cuenta con el SoC M1 basado en Arm de Apple con una CPU de 8 núcleos y una GPU de 8 núcleos. (Modelo A2338/EMC 3578 con dos puertos Thunderbolt 3)
Preguntas 91 Ver todo
How not to loose TrueTone screen replacement?
Hi everybody,
I've already saw different post that answers part of my question "Will I loose TrueTone and autobrightness with a screen replacement". But I want to know if the part that iFixit sells is a virgin part or not (will or will not loose TrueTone...etc).
What's the specific reason that this happens? If I get a screen from a used MacBook, will I loose this functionality? Has anyone tried or have experienced this?
Thanks for he help!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
If you get a new virgin display then you will loose Brightness, FaceTime camera & True Tone services. The issue is the display needs to be calibrated as they requires the system to be complete. Frankly, I really don’t see why Apple makes this hard if not to discourage repair.
If on the other hand getting a recycled display (which is what I use for my customers) then you don’t loose anything! As the calibration was performed and the settings are stored within the displays T-CON logic.
Here's the needed part MacBook Pro 13" (A2338, Late 2020) Display Assembly - Used! and here's the guide to put in on Reemplazo del ensamblaje de la pantalla de MacBook Pro 13" 2 Puertos Thunderbolt de finales 2020
Imagen de MacBook Pro 13" (A2338) Display Assembly
Producto
$549.99
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
Thanks, but is the part that iFixit sells virgin or not?
- de
@benmerino - The link I posted is for a Used display, Not a Virgin one which would then need calibration which you can't do.
- de
Añadir tu respuesta
Ben Merino estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 314
