Saltar al contenido principal
Guías de reparación y solución de problemas para las laptops Acer Predator de 17,3", un grupo de computadoras para juegos de gama alta de Acer. Estas laptops cuentan con una pantalla de 17,3", GPU dedicada y una bahía modular para una unidad óptica o un módulo de enfriamiento.
Preguntas 16 Ver todo
Battery not taking a charge?
My acer predator laptop all of a sudden stopped charging, one night it was charging just fine and the next day it just stopped, it wasnt moved from its spot or dropped or damaged in anyway, just stopped charging
Es esta una buena pregunta?
Puntuación 1
3 comentarios
Try taking out the battery and starting it
- de
Hi @ josh price,
What is the model number of the laptop as printed on the label on the bottom of the laptop?
Have you tried a different compatible charger to see if that worked in case the charger or charger cord is faulty?
- de
@jayeff im about to order a new charging cable, will update when it arrives
- de
Agregar un comentario
1 Respuesta
Solución Elegida
I will suggest checking the charging cable first, if there is a charging light indicating on your laptop and still doesn't get charged then under the laptop you will find a small battery reset buttonhole, using any pin you can reset the battery. Hope this will solve the problem.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
josh price estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 21
Ultimos 30 días: 71
Todo El Tiempo: 861
