CD opening isn't opening
- CD opening isn't opening
Es esta una buena pregunta?
Ali HD1 you really did not give us a lot of information. It sounds like you are saying that your tray is not opening. You should also tell us more about the history of this and what you have tried thus far to fix this. I suggest that you run the Test mode to see if you can make a better diagnosis on what has failed. Sony DVP NS715 Test Mode
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 71
Need a bit more here!
∙ Do you hear any sounds?
∙ Is the player powering up?
∙ Do you get an error code on the display?
- de Dan
Do you have a multimeter?
- de Andrew S
