My gyroscope stopped working, how do I fix it?
i was playing a game on my iphone4 when the character stayed ont the left. i'm supposed to move it using the gyroscope and turning the device, but it won't sense me moving it. there is also no setting on how to fix it or turn it back on. someone, please help me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
Have you tried to reset or even to restore your iPhone?
por
Agregar un comentario
3 Respuestas
Solución Elegida
Oldturkey has pretty much THE solution, reset or restore. There is no fixing (or even replacing) a gyroscope/accelerometer unless you have a microscope, very tiny robot arms capable of soldering, and a lot of know how. If you are still under warranty I would definitely take advantage of that. If the reset/restore doesn't work and you have no warranty, you may unfortunately be fishing for a new logic board.
Fue útil esta respuesta?
Calificación 1
Respuesta Más Útil
Now seriously this just worked for me. My screen stopped rotating after I dropped it. So powered off and on still the same. Phone was in a padded case so I firmly flicked (hit ) it against a hard floor on all four sides, turned it over and repeated .. Now works fine.
Calificación 2
Comentarios:
Yes, I repeated Gary's suggestion and gave the phone a firm tap and screen rotation restored. Unbelievable but true.
por
When u are on main screen and u slide up from the bottom of the phone and u get tools to dim the brightness and set bluetooth on or put in airplane mode... On far right is portrait lock, if its on gyro wont work. Turned it off my prob was solved.
Calificación 2
Comentarios:
That screen does not have a portrait lock button on my phone. I don't know where to find it.
por
Añadir tu respuesta
danieltorres8 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 19
Últimos 30 Días: 95
Todo El Tiempo: 11,204
