Saltar al contenido principal
Laptops hechos por Samsung
Preguntas 342 Ver todo
glass screen hairline crack repair
I recently bought a Samsung - Galaxy Book Pro 360 15.6" AMOLED Touch-Screen Laptop - Intel Evo Platform Core i7 - 16GB Memory - 1TB SSD - Mystic Navy. There is a crack all the way across the screen. I do not want to pay the 450 for the entire assembly. Is there a way to remove the glass part of the screen and mend the two pieces to gather (assuming that they fit perfectly)?
This is the location of the assembly and the part number.
http://www.samsungparts.com/Products/Par...
BA96-07668B
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario
I also have this issue as my Samsung flex 2 screen just developed a hairline crack through normal use of the laptop. This is clearly a defect but Samsung refuse to accept liability. Plenty of forums with multiple users experiencing similar issue. It's a common problem with these 360 Samsung laptops
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Kris Roberts, yes there is but it will require you to purchase some good tools. You would need a LCD screen separator (something like this.)After that you will have to clean your AMOLED screen properly and you will need either OCA or LOCA to use to bond the glass to the AMOLED. So you’ll need a vacuum chamber to remove any bubbles between the glass and the screen. A bonding machine would definitely be another useful tool. If this is the first time you would do such a repair, you would need to practice on some other screens first since this is really not the screen you want to practice on. As you can see this is very involved and requires a special skillset. Yes it can be done but cost of the equipment and skills needed are not easy to come by nor inexpensive. Your replacement screen is not cheap but spending that money will almost guarantee you a successful repair vs. Glass only repair
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Kris Roberts estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 31
Todo El Tiempo: 1,792
