Is it safe to put ribbon cables in a ultrasonic cleaner
Hi
Is it safe to put ribbon cables in a ultra sonic cleaner as I have seen what they do to tin foil
And also any recommendations on what pcb cleaner Solution I should get(it has to be one you can buy in the uk)
Thanks
Es esta una buena pregunta?
2 comentarios
Why are you going to such extreme?
- de Dan
The reason why I I am going to such a extreme is because I have a water damaged connector on my MacBook logic board that I am working on and at first I thought the pins were burned but they were just badly corroded on both the connector and the flex cable and I thought the ultra sonic cleaner may be the least harmful way of cleaning the cable at such a small level but if that isnt really a option I will probably have to tin them and hope for the best.
- de HelloMacOS
