Where are the temperature sensors of the iPhone 8?
I’ve been having problems with my iPhone giving false high temperature warnings, disabling the flashlight and camera flash due to “temperature being too hot” and the most annoying one: The screen can’t go over 50% of the brightness because of this
I tried a new battery that I intend to return now because even after that, the problem remained. I tried with the home button cable disconnected, with the both cameras disconnected etc. None of that has worked, which leads me to believe the problem is in one of the motherboard sensors
I tried looking into the logs after I had already made some posts in r/ifixit and r/iPhonehelp, what I found was what I THINK is the phone reporting missing temperature sensors (https://imgur.com/a/a3NP1mG), perhaps the sensor can’t read a temperature? And a TH_SFLAG_throttled (https://imgur.com/a/JiPkzoE) 16 lines long log that was repeated uncountable times.
That means couldn’t find any actual temperature reading, which leaves me in a dark spot without knowing which sensor is the problem. The only option that remained is covering all those sensors, but I have no idea where they are located at, any help is appreciated!
Es esta una buena pregunta?
