Why isn't my battery charging? M1 chip
Hi guys,
I recently bought a MacBook Pro 2020 m1 for a bargain price as it had a coffee spill on the keyboard. When I acquired it, it worked fine as did all the keys etc but they were crunchy when pressed and the backlight had faded in the middle, so I decided to change the keyboard (more info on that at the bottom).
When I put the MacBook back together, it turned on and the keyboard now works fine, but the battery won't charge. I have reseated the battery connection to the Logic Board many times and I have checked the connection of the Thunderbolt ports to the Logic Board, all seems well, it just will not charge. At one point I had an 'X' through the battery, but now I can get Coconut battery to read the battery data, it just won't charge.
I am using the charger that came with it, I have also tried a MacBook 12” Retina charger and swapped the cables, so it's not that. I am aware the 12” Retina charger couldn't even power a potato, but I tried anyway.
Any ideas? I'm stumped.
By the way - there isn't much information regarding the keyboard change on these, so I will say that the keyboard is rivoted on, as well as screwed on. So unless you have a microscopic rivot gun or you're very steady with some metal adhesive, don't bother. I applied tiny amounts of thick adhesive to the top of the rivots and was very careful not to let it run, worked a treat, but I only took that risk as the MacBook owes me very little money.
Thanks!
Andy.
Es esta una buena pregunta?
3 comentarios
By the way - there are absolutely no traces of liquid on the Logic Board and before the keyboard change, the battery worked fine.
- de Andy
Was there any liquid on the actual logic board when you tore it down to replace the keyboard?
- de Alisha C
No, it was fine. Also, the battery worked fine before taking it apart and (apparently) did so for a couple of months prior to me buying it.
- de Andy
