Saltar al contenido principal
El Xbox original es el primer sistema de videojuegos de Microsoft. Tiene una carcasa negra fácilmente identificable con 'XBOX' blasonado en la parte superior y frontal. La reparación es fácil con herramientas comunes.
Preguntas 171 Ver todo
My Xbox won’t stay on for long and the power button doesn’t work
I just got this original Xbox and it can only be turned on with the disc opening button, and even when it’s on, it only stays on for about a few seconds. Is there any way to fix any of these issues?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
the power button is probably just overused and has broken. opening it and testing with a multimeter on continuity would help you troubleshoot that issue,
as for it shutting down.
try blowing it out with some air, that console is probably ATLEAST 10 years old. it should be opened up and cleaned out completely, new heatsink paste, dusted out with a brush and reassembled. that would be your best bet on why it starts and shuts down after a while.
if you try this and it still does then we can further troubleshoot the issue.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Nathan Caballero estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 190
