Washer does not fill with hot water except in diagnostics mode.
I was about to dive into a hot water valve replacement until I discovered that when I force the appropriate diagnostic function, hot water works just fine. This unit is 2yrs old and was working fine up until this happened.
Es esta una buena pregunta?
2 comentarios
Hi @goldenx,
Please confirm the model number of the washer, in case yours is a different model to what you selected?
Are there any error codes when running the diagnostics?
It may be a faulty control panel key, wiring harness connection or perhaps a control board problem.
You may be selecting "hot' as the temp option and the light may be on but perhaps the control panel is not signalling the control board or there is a problem with the board.
Did you use the Temp button during the selection of a diagnostic test option?
Basically from the control board to the valve is OK but you may need to prove it is OK from the control panel to the control board when hot is selected.
- de jayeff
Model: MNWB765FW1
Error code: F0E4 (bogus error code since hook up is correct).
I'm now seeing other symptomatic issues such as agitator appears to be functioning for delicates rather than a normal cycle selection (indicator).
Is there a way to obtain a service manual before I start tearing into this?
Thanks!
- de Michael Golden
