Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
Tablet won't turn on
Whenever I try to turn on the device it just blinks the notification light 3 times. I’ve tried charging it but no luck. Can someone help?
Update (12/03/2021)
Figured it out. For one it was 5 blinks, not 3, and also you just need to charge it longer it seems. I recommend
90 minutes - 2 hours.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
I would recommend you try a different cable and/or wall wort charger that is a 2a rated one. but it is most likely a cable issue. some use 2 paths of power to charge and if one path is damaged you get slow/no charging.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Jack Swallowell estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 41
Todo El Tiempo: 230
