Saltar al contenido principal
La revisión de 2016 de Apple a su línea de computadoras portátiles dirigida a usuarios profesionales. Cuenta con una pantalla Retina de 15 pulgadas, 2880 por 1800, Intel Core i7 de cuatro núcleos, opciones de almacenamiento de 256 GB / 512 GB / 1 TB / 2TB, 16 GB de RAM y un teclado equipado con una barra táctil. Lanzado en noviembre de 2016. Características del modelo A1707.
Preguntas 260 Ver todo
Keyboard and trackpad not working
Macbook Pro was working fine last time I used it a few weeks ago. Its been powered off since. Started it up today and the keyboard and trackpad dont work. Connecting external keyboard and mouse work fine. Cant boot in safe mode to troubleshoot, again because the built-in keyboard doesn’t respond.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Apple loves making things complex!
If I remember correctly the TouchPad logic is also the USB driver logic for the keyboard. So I’m suspecting you might have had a spill or you used some cleaner which seeped under neath damaging the logic board. Here’s the needed part MacBook Pro 15" Retina (Late 2016-2019) Trackpad and here’s the guide to put it in Reemplazo del trackpad de la Macbook Pro 15" Touch Bar de finales de 2016
While you’re in their check the keyboard cable connector for any corrosion
Imagen de MacBook Pro 15" Retina (Late 2016-2019) Trackpad
Producto
$69.99
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
Thanks, I'll check in to this. There were no spills or anything and I dont use any cleaners on the keyboard or track pad. Its just odd it all of a sudden stopped working.
- de
@sharkdiver72 - In that case the Touch Bar cable would be suspect. What can happen is the batter swells up and presses on it damaging it MacBook Pro 15" Retina (Late 2016-2019) Trackpad Cable. That was less of a problem in series.
- de
Añadir tu respuesta
Brad estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 207
