Saltar al contenido principal
Delgada, liviana y elegante, la Swift 3 es la computadora portátil ideal para trabajar en movimiento. La GPU NVIDIA® más reciente, la CPU Intel® y la batería de larga duración se encuentran dentro de una selección de pantallas: un elegante chasis plateado con una pantalla IPS VertiView de 13,5" con relación 3:2 y 2256x1504 o los colores vivos de una pantalla IPS FHD 16:9 de 14" mostrar.
Preguntas 18 Ver todo
My laptop won’t turn on and is flashing orange lights
On my Acer laptop there is two orange flashing lights on the side, it won’t turn on, I’ve tried turning off all power adapters and holding it down for 30 seconds. Nothing has worked and it’s still not turning on, can someone please help me
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
2 comentarios
Werkt bij mijn niet Ik heb ook geen batterij reset
- de
I have a laptop acer travelmate spin b3 series. I tried to open it but i didn't open so i plugged the charger and the orange light on the side and on the lid started blinking slowly. Then after searching some reasons for almost 30mins it the light on lid started to blink blue for a while then orange. But the light on the side is still orange. How to fix it ?
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
When the battery charge is low the orange light will blink slowly. When the battery charge level is critically low (less than 3%) the orange light will blink rapidly.
But in your case it is fully discharged.  So please follow the steps below
If the battery is not charging with the AC Adapter, perform a power reset:
  1. Remove the battery and unplug the AC adapter or the power cord from the computer.
  2. Press and hold down the power button on the computer down for 30 seconds and then release the button.
  3. Plug in the AC adapter or power cord again, reinsert the battery, and power on the computer.
If the Battery is non removable
Turn off the computer.  Unplug the power cable.   Turn the laptop upside down.
If your system has a battery pinhole reset on the bottom, insert a small paperclip in the battery reset pinhole and hold the button down for 5 seconds.
Connect the power cable and turn on the computer.
Fue útil esta respuesta?
Puntuación 6
4 comentarios:
thank you very much. it helped me a lot.
- de
Yep worked geat on one Acer but not on second one, so new battery ordered off Flebay..!
- de
Thanks very much, that worked
- de
I don't have a removable battery nor a pinhole so what so I do
- de
We had this problem on an Acer Nitro 515-54, nothing worked to fix it. THEN we looked at the BIOS and it was on version 1.01. Downloaded 1.33 BIOS and it fixed the problem. Good Lord! Really Acer?
Puntuación 0
1 comentario:
My Acer Aspire 5733Z started flashing the blue and orange LEDs.
If I disconnected and reconnected the charger the flashing stopped until what seemed be when the battery charging resumed.
I replaced the charger and now my good ol' Acer works again.
- de
I have a laptop acer travelmate spin b3 series. I tried to open it but i didn't open so i plugged the charger and the orange light on the side and on the lid started blinking slowly. Then after searching some reasons for almost 30mins it the light on lid started to blink blue for a while then orange. But the light on the side is still orange. Then whenever i try to lift up the lid. The light on the lid vanishes then the orange light on the side becomes blue. How to fix it?
Puntuación 0
Añadir tu respuesta
Potato Potato estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 46
Ultimos 7 días: 246
Ultimos 30 días: 1,250
Todo El Tiempo: 63,066
