Saltar al contenido principal
Quinta generacion de iPhone. La reparación de este dispositivo es fácil y requiere destornilladores, herramientas de hacer palanca, y paciencia. GSM/CDMA /16, 32, o 64 GB / Negro o Blanco.
Preguntas 2170 Ver todo
What is the adhesive under the battery?
I just wanted to know if I can use ifixit's thermal paste to glue the battery back down.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
3 Respuestas
Solución Elegida
Had a quick look via the parts link, I believe pastes like these:
Arctic Silver Thermal Paste
don't actually have any adhesive properties, they are more designed for processors etc
In most cases with the normal i4 I find the battery has previously been removed/replaced and not stuck down and it hasn't caused any issues.
Imagen de Arctic Silver Thermal Paste
Producto
$8.99
Fue útil esta respuesta?
Puntuación 2
Comentarios:
http://www.alibaba.com/product-gs/476643...
is about the only one I can find that looks like it would work, its aftermarket though.
- de
I repaired a phone and the old adhesive didn't bond well. I believe the client dropped the phone and the battery power connector strap ripped away from the battery, leaving the battery jiggling and destroyed.. The battery has weight, that adhesive is there for a reason.
Puntuación 1
it's really thin double sided tape
any sort of glue that is fairly strong, but is easy to remove again will do
i use thin 3m double sided tape personally and i feel it's good
this is what I use if the adhesive is not there well enough to hold strong or it's worn out like crazy
http://www.amazon.com/3M-665-Double-Side...
usually enough adhesive remains in the phone tough
Puntuación 0
Añadir tu respuesta
Chandler Skinner estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 6,774
