backlight and camera not working after water damage
So i was careless and spilled not a decent amount but not a small amount of liquid and it got into the back of my Macbook Pro so right away i followed ifixits guide and opened the bottom to clean whatever damage was there, after letting it sit i turn it on and it boots up and literally everything works normal and when i shine a bright light up to the screen i can see it displaying normally theres just no backlight (hooking it up to external display shows everything just fine) and when i go to use facetime it says “no camera connected” anyone with knowledge of this can help me?
Update (11/17/2021)
after inspection this was the culprit? am i better off buying a new display?
Es esta una buena pregunta?
1 comentario
Both the display assembly as the T-CON is damaged and the iDP display cable which connects the T-CON to the main logic board will be needed as well.
As long as that's all that got wet you're good to go!
- de Dan
