Saltar al contenido principal
La revisión de 2016 de Apple a su línea de computadoras portátiles dirigida a usuarios profesionales. Cuenta con una pantalla Retina de 15 pulgadas, 2880 por 1800, Intel Core i7 de cuatro núcleos, opciones de almacenamiento de 256 GB / 512 GB / 1 TB / 2TB, 16 GB de RAM y un teclado equipado con una barra táctil. Lanzado en noviembre de 2016. Características del modelo A1707.
Preguntas 262 Ver todo
Why is my replaced battery only charging once it has been drained?
I replaced my battery a second time after the first stopped charging at all. The second battery only seems to charge once it has run out completely and not while plugged in and being used - I have attached a coconutBattery screenshot. Any ideas?
I have updated to Monterey to see if it helps. Here is the current info:
Es esta una buena pregunta?
Puntuación 0
1 comentario
Thank you. I guess there’s not much I can do about that. ☹️
- de
Agregar un comentario
1 Respuesta
Solución Elegida
You have a threshold issue within the charging control logic. Sadly that’s part of the logic board that needs service.
You might want to try the other side ports a try to see if thats better as your system has two Intel JHL6540 Thunderbolt 3 controllers (light Blue marked chips)
Otherwise its within the SMC logic which you could have hit while disconnecting the battery (light Green marked chip)
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Jonathan B estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 60
