Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
A1418 | EMC 2889 | Finales de 2015 | Intel Core i5 de doble núcleo a 1,6 GHz o Intel Core i5 de cuatro núcleos a 2,8 GHz. Lanzado el 13 de octubre de 2015.
What does blinking LEDs 1 and 2 mean?
iMac 21.5” does not power up, no chime is heard. I know that LED codes are: LED 1 on= trickle voltage from power supply is detected by logicboard. LED2 on= logic board has detected proper power from the power supply when the computer is turned on.
The problem is BOTH LEDs 1 and 2 are BLINKING (not ON continuously) when I connect the AC power cable to the mains wall socket. What problem does this point to?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
4 comentarios:
Can you offer some additional details on what preceded things here.
- de
Nothing unusual happened prior to. Thing just suddenly won't turn on.
- de
Where is the light coming from?
- de
Light comes from the vertically arranged LED array on the logicboard.
- de
Agregar un comentario
1 Respuesta
What does the other LED’s telling you?
Imagen
Did you try reseating the RAM? Did you replace the RAM you might have a bad SO-DIMM.
Fue útil esta respuesta?
Puntuación 0
3 comentarios:
The RAM is permanently soldered to the logicboard in this model, and cannot be replaced.
- de
Dan, when I press the power button, the 2 other LEDs remain unlit, #1 and #2 LEDs turn off. When I release the power button, LEDs #3 and 4 remain off and #1 and #2 start to blink again.
- de
@Bernie - Sorry your right! One of the few iMacs with soldered RAM.
I think your logic board is blown then.
- de
Añadir tu respuesta
Bernie estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 540
