Laptop will only boot and work with some key pressed
Hi all,
Here’s a challenge for you. My 2012 macbook air died some while ago, but managed to bring it to life in a very peculiar way.
In short, it will not boot, with or without power cable on. However, if I keep some key pressed, it will boot fine and will work without issue, aside from fan speed on max and zero indication of battery charging (coconut won’t even recognize it) or cable light.
The moment I let go of the keys, within 2 seconds it’ll go dead. I’m writing this with my pinkie pressing the tab key :)
What should I need to replace? Battery, keyboard, or both?
Looking forward to your feedback!
UPDATE: when letting go of the keys, I’ll actually get the shutdown prompt, which if unattended will then turn off the laptop. Almost like the keyboard is constantly sending the power off signal.
Also, Coconut screen grab:
Thanks
/R
Es esta una buena pregunta?
It may take some doing! Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Agregar imágenes a una pregunta existente
- de Dan
Hi Dan! Thanks for the tip. Already had it installed and noticed it couldn't fetch anything from battery or charging status.
/R
- de Rodres
