Saltar al contenido principal
La revisión de 2016 de Apple a su línea de computadoras portátiles dirigida a usuarios profesionales. Cuenta con una pantalla Retina de 15 pulgadas, 2880 por 1800, Intel Core i7 de cuatro núcleos, opciones de almacenamiento de 256 GB / 512 GB / 1 TB / 2TB, 16 GB de RAM y un teclado equipado con una barra táctil. Lanzado en noviembre de 2016. Características del modelo A1707.
Preguntas 262 Ver todo
MacBook Pro 15 late 2016 no backlight
I have this problem on my 2016 Macbook Pro but I don’t think it is related to FlexGate for two reasons:
  1. It has pretty much been a desktop its whole life, closed maybe 10 times. I have a second 2016 Macbook Pro that I use for travel.
  2. It hasn’t and currently doesn’t show any of the FlexGate symptoms such as backlight on when barely opened or stage lights.
Is there another suspect component that could cause this failure, perhaps user serviceable?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
Jim Sorrels exactly what symptoms does your MBP show and what have you checked?
- de
Agregar un comentario
1 Respuesta
There is logic within your logic board which powers the backlight LED’s within the display. While its possible that has failed. This series mostly had the FlexGate problem like the 13” model.
Sadly, Apple never fessed up about it on the 15”. It was less of a chance than the 13” models and it often happened on systems like yours! The display sitting around 45º angle as that was the high stress point on the cable.
Give this a view MacBook FlexGate Fix / Repair: What if the cable is +3mm longer?
In any case I would find a good MacBook Repair person who knows these systems at the deeper level to check if the cable is the issue or if the backlight power circuit needs repairs.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Jim Sorrels estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 79
