Saltar al contenido principal
Repair guides and support for motherboards and CPUs.
Preguntas 145 Ver todo
Why only one LED on Ethernet port is steady ON? There is no connection
Hello everyone,
I have a motherboard MI970 which has two ethernet port, one Intel 82579LM and one 82583V.
The 82583V port was connected to a raspberry Pi. I have noticed that the connection was disconnected and a yellow LED on it is steady on, it doesn't matter if a cable is connected or not.
After I have noticed this issue, I have checked the device manager and the driver under Network Adapter was with a yellow exclamation mark, so I have tried to unistall and reinstall it but disappeared totally. I have checked under hidden devices, and wasn't there.
Also, I have tried restart the system and turned it off for a while. Nothing changed. Since the system is on the LED of the port is ON and is not working.
Also, I have tried to install the driver manually but it didn't allow me to install.
Is there any solution for this issue?
Also, if I cannot use the port and is knocked, can the motherboard be used? I meant it cannot cause any more issues on other parts?
I would appreciate if you could give me some advice.
Thanks in advance,
Milad
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios
What is the exact make and model number of the motherboard?
- de
Thanks a lot @aactech
Intel MI970VF
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi @miladb ,
Is the 82579LM LAN port working OK?
If not check that the PCH Lan Controller setting in BIOS is set to enabled (see p.41)
If the 82579LM LAN port is OK it may be a motherboard problem as the 82583V LAN controller is not being detected by the OS.
Fue útil esta respuesta?
Puntuación 1
5 comentarios:
Thanks @jayeff for your comment.
Yes the other port is working fine.
This motherboard can make any problem for the other parts?
- de
@miladb
Without a schematic of the motherboard (I can't find one) I'm not sure.
If the LAN controller IC has been damaged then perhaps not.
The board may work OK for all the other functions except for that one LAN port.
If the voltage supply to the "damaged" LAN controller IC is affected by the what has happened to it then it may affect other components on the same power supply rail as the IC
You may be able to find the LAN controller IC on the motherboard. Look for a chip with Intel 82583V (supplier example only) printed on it and check if it seems obviously damaged e.g. burnt.
If the yellow light is still on you may be able to either replace the chip or remove it
Is the Pi board still working OK when connected to the other LAN port? Just wondering if it caused the "faulty" LAN port controller to fail perhaps.
- de
Thanks a lot @jayeff
Much appreciated.
Yes, the Pi board is working fine and can connect to internet. All ports working fine.
Also, in the motherboard all ports are working fine, even the usb ports that are in the same unit with the lan.
Many thanks
- de
@miladb
The USB ports use a different controller and most likely have a different power supply rail to the LAN controller. The USB and LAN port connectors being in the same unit is only the design of the connector unit and not what is connected to them from the motherboard
Cheers.
- de
@jayeff
Thanks a lot, I didn't know it's only the design.
- de
Añadir tu respuesta
Milad Bagheri estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 76
