Saltar al contenido principal
Repair guides and support for your Philips TV.
Preguntas 240 Ver todo
no picture back light is bliks once.
LED TV, has sound but no picture back light is bliks once.
Model 43PFT4002S/98
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
bala krishna  Since you have audio , you know that at least part of your main board still works. Now, in a darkened room turn the TV to a station where you have audio. Shine a flashlight at an angle against the screen. See if you can make things out like silhouettes, menus etc. If so, then you know it is your backlight (bad power board, bad backlight array). If you do not see anything then there could be an issue with the main board or the T-con board.
It’s a Philips TV so I am pretty convinced that this is caused by bad backlight strips.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
bala krishna estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 33
