Replaced Battery - Dead, No Charging, No PC Hardware Detect
I was asked to change the battery in an iPod Nano 3rd Gen for a friend. I’m not new to device repair and everything was straightforward in the guide. Soldered a new battery in and the device doesn’t appear to charge and hooking to a PC does not mount the device.
Now, I was asked to change the battery because the unit was dead, but I have no idea for how long. I never saw it work before changing the battery.
They are wanting to keep the content on it, so as a last resort, they ordered another battery and I replaced once again. Same thing… just dead.
I have a USB current meter and I put that in line with the charging cable. The current reads 0.00A output which tells me it’s not even attempting to charge or power the unit.
What I would like to know is whether this iPod should power up with only USB connectivity (and even no battery), or if the unit needs a working battery to operate at all. If it should be detected by a PC with no battery, then I suspect the logic board is dead.
Es esta una buena pregunta?
new batteries have some load. Did the ipod screen turned on after replacing?
Have you tried applying direct voltage to battery wires?
The ipod works with direct voltage, but the charging battery and it logics part is more problematic.
- de AlcRepairCafe
