Why am I get a single grey vertical stripe on my LCD panel?
I tried disconnecting the left and right ribbon bands from the tcon to panel( one at a time). If i disconnect the left side i get on the right side pink stripes the get bigger or smaller as i touch the connection band. If i disconnect the right side i get the same grey stripe as i would get with both sides connected. I checked the voltages and im getting different voltages for left and right output from tcon to panel also on the panel boards i get the same difference. Left side 10 mv , right side 5mV. this strikes me as odd. I also tested the capacitors on the tcon, found notjing wrong. Any idea what it might be?
Es esta una buena pregunta?
8 comentarios
Dércio Fernandes post some images of what your screen looks like with everything connected. Also, let us know what model your TV is. It is possible that this is a T-con board issue but it is also possible that this is a driver board issue. In your picture, you also want to show us where you checked the voltages. Agregar imágenes a una pregunta existente
- de oldturkey03
I uploaded some images
- de Dércio Fernandes
Oh and the tv is a phillips 49pus6581/12
Push gently on the ribbon cables that enter your LCD (The cable that comes from the LED controller board. That is the board where the ribbon cables from the T-Con board go to.) See if that changes the line on your screen. This does not look like a typical T-Con board error.
- de oldturkey03
Yes i have done that but there are no changes
Mostrar 3 comentarios más
