Saltar al contenido principal
La única version con Wi-Fi del Apple iPad 6, lanzada en marzo de 2018. Disponible con 32 y 128 GB de almacenamiento. Dispone de una pantalla Retina de 9.7 pulgadas y de un chip de fusión de 64 bits A10.
Preguntas 150 Ver todo
After replacing the screen, some parts aren’t tactile
Hi,
I replaced an iPad 6 screen but some parts of the screen are not tactile anymore.
Here is an example in Notes, where you can see the two parts that doesn’t work anymore.
FYI Someone gave me this iPad; He forgot it on his car roof and someone drove on it.
Thanks!
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
I have had this occur in the past with screen replacements. Each time, the issue was at the connector. Under the scope, you could see the pins not connecting securely with the ribbon cable. Not sure that this may be the issue you’re having, but it would be worth checking.
Fue útil esta respuesta?
Puntuación 1
Thank you for your help!
You were right, the pins were of very low quality, some broke when I opened the screen again.
I just asked for a return & refund.
Puntuación 0
Añadir tu respuesta
Lulucmy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 43
