Saltar al contenido principal
El primer modelo de iPhone, modelo A1203 con 4, 8 o 16 GB de capacidad y una parte posterior de aluminio. La reparación requiere una cantidad significativa de destreza, y puede requerir un poco de soldadura.
Preguntas 221 Ver todo
Broken Sim Reader Pins
Hello,
I always wanted a first generation iPhone and I bought a first generation IPhone to repair. I realized that my device is not reading SIM cards. Then I opened it and saw the broken pins. Can I just buy a broken motherboard and replace the sim slot? If not how could I fix it?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
I have replaced sim holders on a lot of iPhones but not this model. It looks easy enough. I am not sure how much heat you will need to melt the solder on these models, if you flow the joints with low melt solder you shouldn’t have a problem although you will probably need a hot air station as well as an iron.
The hardest part will be finding a non-working one to buy.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Thank you so much?
- de
Añadir tu respuesta
Batu Köseoğlu estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 23
