Saltar al contenido principal
Información de reparación de congeladores.
Preguntas 192 Ver todo
Where is the defrost heater thermostat?
Whirlpool stand up freezer (WZF79R20DW00) evaporator iced, (fixed) checked thermister (6-7K ohms) heating element has continuity, cannot for the life of me find/locate the defrost heater thermostat to see if that is functioning. Need a pic or where to look for the thermostat! Thanks!”
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi @raybo99 ,
Here’s some information that may help.
According to the parts supplier below the Cover sheet part # is W10747668.
On p.3 Cabinet parts of the above document it shows that the tech sheet is part #W10653921.
This sheet details the diagnostic test modes and also has the wiring diagram.
Looking at the parts diagram for your model, there are only 2 thermistors shown.
They are shown as part #3 Liner parts diagram and part #9 unit parts diagram.
I think that part #9 is the defrost thermistor as it looks like it is meant to clip onto the evaporator unit or close by.
The wiring diagram shows that the evaporator thermistor (defrost thermistor?) can be tested from the control board connector CN2 pins 1 & 2
As best that I could find out regarding the specifications for the thermistor (part #WPW10383615) is that at room temp of 77°F the resistance should be 2.7KΩ (2700Ω) and at 36°F (in ice water) it is 7.964KΩ (7964Ω). being an NTC (negative temperature coefficient) type thermistor the warmer the temperature the less the resistance.
Regarding the defrost thermistor part number see Note.4 on p.2 of the sheet
Although if the actual model number (not a Whirlpool part number) of the thermistor is visible on it then try verifying the specifications by searching online using the model number only to see if they’re available. It should never measure open circuit.
Looking at the wiring diagram in the tech sheet it also shows that there is an inline thermal fuse connected on the brown wire between the harness connector and the heater element although I cannot find it listed in the parts diagrams. It may also be worth checking if you can find it and test if it is OK also given that you said that the defrost heater element is OK.
Note: Currently there is a bug when viewing .pdf documents on Ifixit where if you have to magnify the document for easier viewing then there is no ability to move the document sideways to view what is now missing due to it being too large for the screen, i.e. no horizontal slide bar at the bottom of the page. You can still scroll up and down though. If you wish to view it magnified then download it from the document page and then open it and view it on your PC as it will work OK there. The Ifixit admin are aware of the problem and are working on it.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Ray Powers estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 540
