Saltar al contenido principal
The Ford Expedition is a full-size SUV assembled by the American automaker Ford Motor Company. Introduced as the four-door successor of the two-door Ford Bronco, the Expedition has remained in production since the 1997 model year; it is currently in its third model generation.
Preguntas 77 Ver todo
How to hook up my alternator to battery on ford expedition 98
What are steps to connect alternator to battery on 98 ford expedition ? Tried everything changed solenoid , alternator, battery, cleaned terminals and expedition will not start when turning key it just makes click sound
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Nicole Gonzales this does not sound like an alternator issue per se unless of course your (new) battery is empty. Check the battery connectors post and see if the wires are corroded etc. Let us know if your vehicle starts with a boost from another vehicle etc. Try to use a multimeter and check to see if you get power to the starter. ALWAYS MAKE SURE THAT YOU SECURE THE VEHICLE SO IT DOES NOT ACCIDENTALLY MOVE!!!! Check something like this and let us know what you find out. Ultimately a quick attempt to hit wire the starter will show if that works. If so you need to check the starter relay and see if you get power to that.
Let us know what engine you have in your Expedition so we can see if there are any know issues with it
SInce you specifically ask for the wiring here is the wiring diagram for a 1998 Ford Expedition
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Nicole Gonzales estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 244
