Saltar al contenido principal
The 5th generation BMW 3 Series is based on the E9X platform. The car pictured is a E90 chassis. The E9X chassis was used from 2004-2013 when the F1X chassis was released. When talking about a non-specific chassis, this generation is typically referred to as the E9X chassis since there are multiple chassis for this generation of 3 series, depending on the body style (E90/E91/E92/E93).
Preguntas 28 Ver todo
Why is my brake pedal solid with the vehicle is stationery
Have a strange brake pedal problem.
Good pedal when at standstill but with engine running pedal is to the floor and wont pump up. All fluid levels good and have bled the brakes with no bubbles. Vehicle is un-driveable. Can you help?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi,
Check the brake booster check valve is OK or for a leak in the brake booster/brake booster vacuum hose etc.
Here’s a link that may help explain it.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Alan Parker estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 33
