I replaced my screen and battery. Shows no sign of turning on.
I purchased the screen and battery replacement kits and went through the process of replacing both components on my Pixel 3 XL. I had no trouble through the repair but after reconstructing the phone it shows no signs of turning on, charging, etc. I followed both tutorials to the letter and I’m not sure what could be causing a complete lack of function. I’ve gone back through to double check every connector twice now and I’ve got no screws or anything left over. I have also tried with the old battery and there has been no change.
The phone worked fine before, just a cracked screen.
Es esta una buena pregunta?
When plugged into a charger the motherboard and battery connector warm up. No more than you'd expect, but enough to show it is taking a charge. Still no display or vibrate to suggest it is turning on.
- de George Johnson
Try removing the new display and connect the cracked one to see if it lights up.
- de GKJarhead
Got it diagnosed by a local shop, apparently something on the motherboard got knocked or damaged, so motherboard replacement is next on the list.
- de George Johnson
