Saltar al contenido principal
El Samsung Galaxy S3 es un teléfono inteligente multitáctil con formato pizarra, capacidad de seguimiento ocular, mayor almacenamiento y una opción de carga inalámbrica.
Preguntas 20 Ver todo
Won't Charge Or Displays Caution Sign During Power On Attempt
I know this is a pretty dated piece of tech, but I have pictures and contacts in the device that I need. I’ve tried different chargers and different plugs, but the result is the same. Changing batteries have given me the results of a black screen or a caution sign inside the “charging battery” animation upon start up. I’m just looking for some help so I can get what I need off of there. If anyone has any ideas I’m open to any and all of them. Thank you.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
I repaired alot of these devices back in the day and the fault you are describing is almost always the Charging Port Flex Cable.
Fue útil esta respuesta?
Puntuación 0
3 comentarios:
What exactly do I have to do to the flex cable? Is it loose or do I need to replace it? And where is it located?
- de
@jjmarcus143 Sorry, I thought it was a Galaxy S4 for some reason. Galaxy S3 is just a port, not a flex cable. But unfortunately, I'm not sure what could cause this on this model.
- de
Dang. Alright I appreciate the response.
- de
Añadir tu respuesta
Jamarcus estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 13
Todo El Tiempo: 80
